Help needed - TechnoTrend 3650
sl888y
Hello Everybody,
Recently purchased a sat display system,
Unfortunately not all of the channels are displayed
full screen or not at all(black screen) , There are two channels which are very importend to me because there are the only channels in my mother toung. (Sat info and provider are in the SatInfo.txt file)
The channels i do see displayed on the upper right corner of the screen(example:ChanellDispaly.JPG)
more information is attached in " ProgramDefinitionsSceernShots" folder
My system setup is:
computer:
http://eu.computers.toshiba-europe.com/cgi...ODUCT_ID=144980
Digital receiver:
http://www.technotrend.de/2715/TT-connect__S2-3650_CI.html
Viewer:
DVBViewer as was downloaded just tow days a go form the here:
http://www.DVBViewer.com/members/
Display Adapter info
DisplayAdapterInfo.txt.txt
Display:
HDMI Connected
Also attached support.zip as reqested
Thank you all for any help
rasputin
ProgramDefinitionsSceernShots.rar
hi,
An update:
Checking the "VMR fix" check box solve the display problem, now the display is full screen.
