Splitted recordings
MomoBrut
How can I play splitted recordings from OSD recordings? The splitted record is playable from the menu, but its first part only. Other parts are recorded, but they are not playable directly from OSD recordings.
Nobody experienced this problem? Nobody splits its recordings? If someone splits, how he plays those recordings?
I splitted recordings, but not any more,
i had to get them together in one file. (using nero vision)
I would not play it from DVBViewer
But you can in windows explorer select the series of the splitted recording, right click and add to qeue it up in windows media player (i have version 9) or add to playlist in wmp.
Works fine.
greetings
Bernhard
Edited by bph
