Only stereo Audio Playing DVD
ardua97
Hello
i have a htpc with vista
, DVBViewer 3.9.1
and a 5.1 Creative speaker system connected to the pc
in DVBViewer as audio directx i chose Cyberlink audio
but the same dvd if played in cyberlink powercinema it work correctly
the rear sound are played by the rear speaker
and played in DVBViewer all the sound are played from the two frontal speaker
it work as stereo sound
is this a limitation of DVBViewer or i mistake something
of course you have to setup the cyberlink audiodecoder in view -> filters and you have to select a suround audiotrack. If you have a stereo audiotrack, you get stereo.
thanks for it answer
I will proof as soon as possible
it worked finelly
thank you very much
