Dvbviewer Fails...
straits
Hi, I've be purchased my 3.9xx version after i 've tryed the demo version and my problem is that DVBViewer fail after 15 or 30 minutes with a login and passwd window......
I have all in good conguration and I don't want to re-install again.....
Please help me.
my e-mail
uninstall the viewer completely including deleting the program and userdata folder. then do a clean install an make sure you enter the username and password correctly while installing.
Thanks a lot , lars, I might re-configure again...
