MXM Posted March 4, 2008 Posted March 4, 2008 (edited) Forgive me if my searching skills failed, but I haven't found and explanation for this problem. I have HVR-4000, which is an S/T hybrid card, and I use both in DVBViewer. If I was watching a satellite channel before turning the program off, it will start normally next time. But if a terrestrial channel was on, it will start and immediately give "DVBViewer.exe has encountered a problem and needs to close" error. No picture, but sound still goes on for few seconds. So I am forced to start it with "DVBViewer -c1" command line (S-channels are listed first here) and then switch to a terrestrial channel, only then it will work nicely. It worked fine before, I don't really know what changed, it just started to behave like this at one point. How would I start to trace this problem? So the card is HVR-4000, motherboard is gigabyte p35-ds4, videocard is 8800gts (FW 163.71). Edited March 4, 2008 by MXM Quote
Lars_MQ Posted March 4, 2008 Posted March 4, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
MXM Posted March 4, 2008 Author Posted March 4, 2008 Ok, I don't know what happened, must be a demo effect. I tried to replicate the problem so the necessary error logs would be generated for the support.zip, and I can't make it crash anymore. So thank you for your time, and ignore/delete this thread Quote
