Valts Posted March 4, 2008 Posted March 4, 2008 Hello, I was really wondering is it possible to get Signal strength, bitrate, resolution displayed with skins activated or in OSD? As that is a bit a bit annoying that have to disable skin to see the statusbar. Also I checked out OSD skin editor to see if I could add that data there, but couldn't find out how to do that TIA, Valts. Quote
Valts Posted March 6, 2008 Author Posted March 6, 2008 Hmm, is there somewhere official support I can reach then? Quote
ArneF Posted March 8, 2008 Posted March 8, 2008 On the statusbar you can click on the second from left to see the level. Arne... Quote
Lars_MQ Posted March 8, 2008 Posted March 8, 2008 osd -> system -> info. Or if you use a other skin OSD -> htpc -> info Quote
Valts Posted March 9, 2008 Author Posted March 9, 2008 osd -> system -> info. Or if you use a other skin OSD -> htpc -> info Found it, very well hidden thanks. Quote
