hhh Posted March 6, 2008 Posted March 6, 2008 Hi guys, I just came back to DVBViewer after a couple of years without a tuner, and boy is this software nice. I do have a small issue, I want to resize the image to be exactly the broadcasted size (to eliminate scaleing). I can't imagine where is not a shortcut or button for this, but i can't seem to locate it. Thanks in advance. Quote
Lars_MQ Posted March 6, 2008 Posted March 6, 2008 rightclick into the DVBViewer window, select view -> zoom -> 100% Quote
hhh Posted March 6, 2008 Author Posted March 6, 2008 rightclick into the DVBViewer window, select view -> zoom -> 100% Sweet.. Thanks! Quote
hhh Posted March 6, 2008 Author Posted March 6, 2008 Ok, I'm pretty confused now. When I play back a TV recording at native resolution (in media player classic or VideoLAN) the picture gets a bit bigger (about 10%) than with the native 100% zoom in DVBViewer. I tryed recording as .mpeg and .ts with the same result. I find this very wierd, as the stream should be the same in the broadcast and the .ts file? Quote
Derrick Posted March 6, 2008 Posted March 6, 2008 ..why do you want to do that? Are you sure you're not confusing things? Broadcast and native resolution are not the same. Quote
hhh Posted March 7, 2008 Author Posted March 7, 2008 (edited) ..why do you want to do that? Are you sure you're not confusing things? Broadcast and native resolution are not the same. I don't think I'm confusing things, but maybe I am? If I do a zoom > 100% in DVBViewer the window resized to the resolution of the channel. If I then start recording the same channel, and open the recorded file in VideoLan or MediaPlayer and resize the image the resolution of the recorded file (equivalent to zoom 100%), the image just gets bigger. Not always 10% bigger, on some channels about 40%. It's very odd. Edited March 7, 2008 by hhh Quote
J.B. Posted June 11, 2008 Posted June 11, 2008 I'm looking for the same feature. I want 1920x1080 to zoom 1:1 pixels onto my 1680x1050 screen, i.e. zoom until 120 lines have been cut off on each side and 15 lines top and bottom. The method described in post#2 downscales the image to fit my screen size and for some reason switches from fullscreen to windowed mode. And another zoom question: is there a way to increase the steps of the Zoom Up / Zoom Down commands? Right now I have to zoom in 23 times just to get rid of the 16:10 borders on a 16:9 broadcast. Thx for any answers. Quote
