Auto Mapping XMLTV to channels
The One
Hi all,
Is it possible to make a auto mapping program to match the XMLTV format channels to the channels in the channels.dat file?
For example possible working:
Does a search for channels present and maps 100% matches and leaves non matching channels for manual mapping giving you the options available in a log file.
or such
I think this would help a lot of people who have a thousands/hundreds of channels and don't what to spend days mapping them, if using the XMLTV format.
Let me know if it is possible or another solution available.
Thanks
Well, actually such a thing is on my todo list. Might take some time. :)
That is great. Any time frame to implement?
I have some work to do with a bit higher priority (hit the link in my signature, then hit the forum link to go to my thread).
I have promised to do that in the very first post. So I cannot supply any time frame, sorry.
Well, Auto pairing (mapping) of channels is now available: www.a123.dk ;)
;) excellent, Now that was quick!! I will test today and let you know.
