ardua97 Posted March 7, 2008 Posted March 7, 2008 when i put the MHP Carousel Plugin in plugin folder and then start DVBViewer the program crash i have windows vista this is the text of the error Firma problema:Nome evento problema: APPCRASH Nome applicazione: DVBViewer.exe Versione applicazione: 3.9.1.1 Timestamp applicazione: 2a425e19 Nome modulo con errori: ntdll.dll Versione modulo con errori: 6.0.6001.17052 Timestamp modulo con errori: 474ffcc8 Codice eccezione: c0000005 Offset eccezione: 000367b9 Versione SO: 6.0.6001.2.1.0.768.3 ID impostazioni locali: 1040 Informazioni aggiuntive 1: bfef Ulteriori informazioni 2: e8adce1c2b9e7be834b4063ac3c53863 Ulteriori informazioni 3: bfef Ulteriori informazioni 4: e8adce1c2b9e7be834b4063ac3c53863 and i attach also the support.zip Quote
Lars_MQ Posted March 7, 2008 Posted March 7, 2008 Solution: Don't put the mhw plugin into the plugin folder. It's old and does most propably not work anymore with the current DVBViewer version. Quote
ardua97 Posted March 7, 2008 Author Posted March 7, 2008 Solution: Don't put the mhw plugin into the plugin folder. It's old and does most propably not work anymore with the current DVBViewer version. ok thanks there is some think to read mhp data from channel in DVBViewer ? Quote
