DVBViewer frozen
entrecour
I mistakenly shut down DVBViewer whilst it was in the process of starting up. After rebooting DVBV doesn't work - it's completely frozen apart from menus that I can pull up in the system tray icon.
I uninstalled the program folder and reinstalled again and still the problem persists. I am not going to be at popular at home as I have packed away our STB so I need some help soon.
Support data attached.
Thanks.
08/03/2008 23:45:43 EAccessViolation raised by instance frmMain of class TfrmMain at 05DEFD43:Zugriffsverletzung bei Adresse 05DEFD43 in Modul 'ffdshow.ax'. Lesen von Adresse 00000000
start the viewer with "DVBViewer.exe -c" and then change the decoder settings in options->directx.
Hi Lars,
Your suggestion worked perfectly. Thanks!
