dagfredr Posted March 9, 2008 Posted March 9, 2008 Hi, I have been struggling since yesterday. The installation seemed to go fine. Channels are found during channel scan, and I can select a number of channels in the Norwegian terrestrial network (NTV), But regardless of what channel I try to view I get "Cannot render media file ..... Error 0X80040200" in the first message box and then no real picture, just some colours. In some cases the application crashes. I am using a Hauppauge HVR900. The PC is a DELL Dimension 8400 running at 2 GHz and using WinXP-SP2. Does anyone have an answer? I have attached the support file. support.zip Quote
hdv Posted March 9, 2008 Posted March 9, 2008 Hello, you hadn't made settings in Option -> DirectX, select the CyberLink or MainConcept Video Decoder for Video and the same for Audio. Quote
dagfredr Posted March 9, 2008 Author Posted March 9, 2008 Hello, you hadn't made settings in Option -> DirectX, select the CyberLink or MainConcept Video Decoder for Video and the same for Audio. Sorry that I did not include all my tests, but I have tried a number of decoder settings, and the one that is included in the zip file just happend to be one with Sytem default. I retried with the setting you suggested, but no result. Thanks anyway Quote
