lummer Posted March 9, 2008 Posted March 9, 2008 Hallo, ich habe immer wieder das Problem, dass die Aufnahmen im .ts Format ruckeln, bei MPEG jedoch nicht. Das gleiche tritt auch bei anderen Programmen auf. support.zip Quote
lummer Posted March 13, 2008 Author Posted March 13, 2008 Ich habe es mal mit MpegRepair überprüfen lassen entweder ich bekomme das: Sequence Frame 24(10- / Time 0:00:00 :VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 97226 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 99482 VideoWarning: TemporalRef gap of 3. Timestamp gap of 0.040000 sec. ending at file offset 103054 VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 120350 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 122982 VideoWarning: TemporalRef gap of 3. Timestamp gap of 0.040000 sec. ending at file offset 125426 VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 142346 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 145166 VideoWarning: TemporalRef gap of 3. Timestamp gap of 0.040000 sec. ending at file offset 147798 VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 162838 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 164906 VideoWarning: TemporalRef gap of 1015. Timestamp gap of 0.440000 sec. ending at file offset 167275 Sequence Frame 36(10- / Time 0:00:01 : VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 230706 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 233150 VideoWarning: TemporalRef gap of 3. Timestamp gap of 0.040000 sec. ending at file offset 236534 VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 259282 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 262290 VideoWarning: TemporalRef gap of 3. Timestamp gap of 0.040000 sec. ending at file offset 265110 VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 280150 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 282218 VideoWarning: TemporalRef gap of 3. Timestamp gap of 0.040000 sec. ending at file offset 284474 VideoWarning: TemporalRef gap of 1021. Timestamp gap of 0.040000 sec. ending at file offset 316434 VideoWarning: Timestamp gap of 0.040000 sec. ending at file offset 319630 VideoWarning: TemporalRef gap of 1015. Timestamp gap of 0.440000 sec. ending at file offset 325571 ... oder bei Anixe HD: Sequence Frame 1093(0-X) / Time 0:00:40 :VideoWarning: Discontinuity of (1+) packet(s). First packet ending at offset 46581136 VideoWarning: Discontinuity of (1+) packet(s). First packet ending at offset 46581324 Sequence Frame 1959(0-X) / Time 0:01:16 : VideoWarning: Discontinuity of (4+) packet(s). First packet ending at offset 105292596 Sequence Frame 2137(0-X) / Time 0:01:24 : VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 120638660 Quote
lummer Posted April 12, 2008 Author Posted April 12, 2008 die Aufnahme mit ts ruckelt sehr stark, bei Anixe HD war es jedoch nur manchmal wenn es zu den Discontinuities kam. Ich habe an der Symbolrate rumgeschruabt, jedoch ergab sich keine Verbesserung Quote
