Sunracer Posted March 10, 2008 Posted March 10, 2008 Hi! Every now and then my DVBViewer Pro (3.9.x) seems to "freeze up" or become sluggish when it's supposed to be recording something. What happens is that when a recording timer activates, DVBViewer doesn't change to the right channel and the UI becomes quite unresponsive. It might take 1-5 secs for the menu to open, for example, or any dialog button to register a click. When I then manage to manually switch to the correct channel, DVBViewer immediately starts to record and UI becomes responsive again. Until the next program is supposed to be recorded, and the same thing happens again. This is not the norm. The problem happens on some days but not on others. Rebooting the machine or updating the DVBViewer software doesn't seem to have an effect. Anyone else had the same problems? I have Terratec Cinergy 1200-C with the 4.8.17 BDA drivers. -Sunracer Quote
Lars_MQ Posted March 10, 2008 Posted March 10, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Sunracer Posted March 15, 2008 Author Posted March 15, 2008 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Hi! I've attached my support.zip. Couldn't think of any other information to add. support.zip Quote
Tjod Posted March 15, 2008 Posted March 15, 2008 Disable the Unicast Network Device (Options > Hardware) again. Quote
Sunracer Posted March 16, 2008 Author Posted March 16, 2008 Disable the Unicast Network Device (Options > Hardware) again. Thanks for the tip! I'll see how it starts to behave now. -Sunracer Quote
