Asks for name & password then closes down!
kirkholm
Hi, paid up and registered yesterday. Now find after about 20 minutes I am asked for my name and password and the viewer then closes down. Whats going on please?
It seems as if a other Version was Installed before this.
Uninstall the DVBViewer including the Configuration files.
If you Install than the DVBViewer with your password it should work.
Thanks, That seems to have solved the problem.
