Transedit doesn't find any channel
Pipeline
First off, sorry for my bad english :mellow:
I just plug my new hrv-4000, installed the cd drivers and powercinema and check all works ok , i downloaded the Transedit soft that if i'm not wrong, i must use this software to check if my tvcard works well with DVBViewer and also i can find all my channels
I'm talking to seach about the dvb-t channels from Spain, i selected "Terrestrial EUR" and Freq from 50 to 858MHZ, Scan All and after few mins i found 0 channels (As i said, at powercinema i'm able to see all my dvb-t spanish channles without problems
So please, some light here :bye:
Regards!
Ok Solved! :bye: I uncheck the box "Open whole transponder" under options menu
Regards
