How to pause a recording ?
Jabba355
Hi
Is it possible to pause a recording and then to restart it once the commercials are finished ?
I am currently removing them after the recording is completed with video-redo but it would be much easier and quicker to remove them at the time of broadcast..
Cheers
Jab
That's not possible. you can disable a recording and start a new file if you enable it. But you can not pause a recording.
Is there a technical reason why this cant be done, or just a feature that wouldnt be of any interest to most users ?
Yes, due to the MPEG2 video compression. Frames can't be split and concatenated randomly, because they are not independent from each other (in contrast to MPEG2 audio frames). Some frame types ( P and B ) contain information that is based on previous and subsequent frames. Or with other words: They only contain the difference between pictures.
A pause or gap would mean concatenating frames that don't belong together, resulting in artefacts on playback or even a decoder crash.
