Signal levels with Anysee E30
Hammaskejju
Hello all!
I have DVBViewer running with Artec T14 and Anysee E30. Both works fine with DVBViewer. Signal level with Anysee E30 is 90% and with Artec T14 the signal level is little under 80%
There were hanging problems with USB, so I had to change the hardware. (Motherboard, processor, memory, etc...)
I have installed the DVBViewer to a new computer. Then I copied old "C:\Program files\DVBViewer" -folder to the new computer. I allso copied "C:\Documents and settings\All users\Application data\CMUV\DVBViewer" -folder to a new computer.
After this everything works fine. All settings are in place, and channels are tuned etc.
But somehow the signal level shows just 7% when using Anysee E30. With the With Artec T14 the signal level is fine (~80%)
The picture looks and works fine with Anysee E30, but the 7% signal level worries me too much. Should I do something about it?
The signal level is ok in the software that came with Anysee.
I really can't get sleep, until the signal level is back in 90%
Anyone?
