rickycy Posted March 17, 2008 Posted March 17, 2008 I try to record my TV using DVBViewer, I find that some of the channel will return "Fatal Error! Stopping recording file", however, some of the channel is normal randomly. Do you have any idea why it will happen? Please advise. Thanks! Ricky Quote
Lars_MQ Posted March 17, 2008 Posted March 17, 2008 Enough space for the recording? Fatal Error only occurs if the recording can not be writting. Quote
rickycy Posted March 18, 2008 Author Posted March 18, 2008 I am quite sure that i have enough free harddisk space. Is it related to video / audio decoder that I am using? It's strange that the recording will work sometimes randomly. Thanks! Quote
Lars_MQ Posted March 18, 2008 Posted March 18, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
rickycy Posted March 19, 2008 Author Posted March 19, 2008 I attach the support.zip for your reference. Thanks for your support. support.zip Quote
Lars_MQ Posted March 19, 2008 Posted March 19, 2008 chinese recording filenames. Could be a problem. can you try to change the filename setting in options -> recordings to %time_%date_%station without any title or other epg part? Just to verify this is the problem. Quote
rickycy Posted March 20, 2008 Author Posted March 20, 2008 I change the filename from %time_%date_%station_%event to %time_%date It works fine now. Thanks for your help. So, I shall wait for your next release to fix the chinese EPG problem, am I rite? Ricky Quote
