Windowdef en français
wxyzkmi
Bonjour,
Pour ceux qui sont intéressés voilà la traduction en francais du fichier windowdef.xml.
A mettre dans le répertoire CMUV habituel ou de DVBViewer selon votre cas.
Au plaisir.
Le programme ayant été amélioré ce fichier n'est plus utile.
Edited by wxyzkmi
What is the reason for translating this file?
Everything should be translatable via Français.lng file.
I was wondering about the same. :bye:
Except error in the file version french.lng the windowdef.xml this is not therefore can not be in french ??
It has to be done with MenuEdit.
That's what I realized.
Edited by wxyzkmi
:bye: !
...maybe you linked a wrong image...
(BTW, why you've put it in a pdf??? ;))
:bye: !
This is the only way to show what I see on the screen
When the language is French or Italian windowdef is in the English, ok
Edited by wxyzkmi
providing this file may cause trouble with some skins, which rely on a special tailored windowdefs.xml. This will cause the users to think there a bug, this will cause postings here with us trying to figure out what's wrong and so on... ;)
I do see your point and understand your intentions. Maybe I can solve the problem at the root and change the text in the options page to the text, which is also displayed in the OSD (and is translated). Would this be agreeable for you? :bye:
Certainly.
Your solution seems more appropriate than to translate the windowdef.
Now I see too; the Lars solution for sure can be a step ahead, anyway the most visible part, the pages title in the OSD (e.g. "Main Menu", "Home Theatre", "My Pictures" and so on...), will still remain in english, as they are part of the OSD background's images, often very difficult to change: infact till now there aren't french or italian translation of any OSD skins...
:bye:
[ :bye: Wait and see the result of the work of Lars.
Edited by wxyzkmi
