DVBServer and clients
Curlo
1. Let imagine that someone is watching something from satellite through DVBServer. I think it would be nice if DVBServer could send for new clients which channel the first client is watching by text message like you can write through server window, so they could change to same transponder and channel list would only show those channels which are available. Now if someone is watching something from 1 tuner sat system, new clients have no idea what someone is watching (or are they any existing clients) and impossible to find out so they brake the stream for first client by changing channels.
2. Also another nice feature would be a automatic network wake-up feature for client by using lan magic-packets. So if server's windows is on sleep, any client starting DVBViewer would automatically wake-up server. Now I wake up server manually by magic-packet program.
In the membersarea is a WOL activeX dll. You can use it with a vbs script. And you can integrate VBS scripts into the OSD Skin with the menueditor or by custom ActionsID.
Or you can use a oldfashoined BAT file to first wake your server and then start the viewer.
Just be a little bit more creative.
