j_fitl Posted March 19, 2008 Posted March 19, 2008 Hi, I have Technisat Skystar HD2 card and I have a problem. If I install DVBViewer Technisat Edition, everything OK, except picture quality. Then, I bought DVBViewer PRO, picture is nice, but, CI slot doesn't working. Uncrypted programs like as CT24 or TA3(Im from Czech republic) working great, but crypted programs like as CT1, CT2, STV .............. only black screen, no picture no sound, nothing. Now, I would like to ask you, if you know any solutions? Quote
balky Posted March 20, 2008 Posted March 20, 2008 nobody knows, where is a problem? Maybe you need to check the firmware version on your CAM module, I had the same problem two weeks ago with TV-Vlaanderen (Belgium) but of course mine was always working until it stopped about two wweks ago, I had to upgrade the firmware of my CAM module to get it working again... goodluck... Quote
blizzarduk Posted March 20, 2008 Posted March 20, 2008 Have you made sure it is using the cam in the DVBViewer settings ? Maybe tick "only send encrypted channels to CI" just to see if it makes a difference, I can't be sure it will. Quote
j_fitl Posted March 20, 2008 Author Posted March 20, 2008 Maybe you need to check the firmware version on your CAM module, I had the same problem two weeks ago with TV-Vlaanderen (Belgium) but of course mine was always working until it stopped about two wweks ago, I had to upgrade the firmware of my CAM module to get it working again...goodluck... I try to update CAM moule (easy.TV by Mascom) and it tell me, that is no update for my module, I have firmware from August 2006 Quote
j_fitl Posted March 20, 2008 Author Posted March 20, 2008 Have you made sure it is using the cam in the DVBViewer settings ? Maybe tick "only send encrypted channels to CI" just to see if it makes a difference, I can't be sure it will. Yes, I have tick it, but If I untick, then still doens't working Quote
