Glitches
Hi!
I did something bad when i didn't check up the forum rules before i did my first post, I can understand that and I'm terribly sorry
But also i pay for this product so I think I deserve some support, sure I can call but that would cost me alot (dunno if it's a free number) and i don't feel
for talking about it via telephone as my english is not so good.
So I hope admins can forgive me (even if you consider making a new account lame).
I got a major problem with DVBViewer (which btw is a great tool for capture/watching tv).
It randomly gives me glitches (within 20 minutes often) for no reason and I've tried different filters/mixers/decoders without any improvement (doesn't matter if DVBViewer is set to normal/high/realtime priority).
I also changed Smart Buffer from not using it to 100MB without any difference.
This didn't happend to my old box (Intel Pentium D, 1GB RAM)
Now i got a quad-core instead and 2GB RAM.
When i watch HDTV the cpu doesn't even pass 30% CPU-useage so i find this really odd.
I use a CA-modul via DVB-C (Conax).
This happends to normal SDTV aswell but not so often as HDTV.
I'm using DVBViewer 3.9.3.10 Beta because I was hoping maybe a newer version would help but it doesn't seem that way
Thanks..
You should read the Forum Rules.
§ 15
The use of multiple forum accounts is not allowed.
_nex will be disabled permanently and nexx get three days extra writ ban.
I did format C:\ with no success and I also searched more in this forum, found out that the problem is simular to this one:
http://www.DVBViewer.info/forum/index.php?showtopic=19080
I tried the aluminium thingie but it didn't help at all.
I installed a separate VideoRecorder plugin and activated the log function which showed something interesting.
15:31:47 Start
16:09:45 Errors: 2 @2477,8 MB
16:14:05 Errors: 3 @2544,1 MB
16:18:25 Errors: 3 @2610,4 MB
16:22:45 Errors: 2 @2676,5 MB
16:22:46 Errors: 1 @2676,8 MB
16:27:05 Errors: 2 @2743,0 MB
16:27:06 Errors: 1 @2743,2 MB
16:31:26 Errors: 3 @2809,3 MB
16:35:46 Errors: 3 @2875,9 MB
16:44:26 Errors: 2 @3008,2 MB
16:46:37 Stop
As you can see, it didn't glitch until 40 minutes after, but when it happend it started to glitch in a row of 4 min 15s.
Going to try TwinhanDTV if it will work there.
(this message is supposed to be a edit of my first post)
EDIT: TwinhanDTV doesnt seem to work at all, and im too lazy to check the problem up at a another computer.
One thing is interesting though,
As i said before, the glitches is in a row of 4min 20s which is 260s.
PMT = 260 for that channel, is that relevant?
Btw, it seems to work with every other channel
Any idea about it?
..hmm, welcome back :blush:
I suspect your problems are related to DVB-C and in particular to 256QAM channels. Could you pls. indicate the channel parameters (frequency, modulation and SR) of a good and a bad channel?
Heh thanks :blush:
Those channels im viewing has 64QAM.
One good channel (SDTV):
Frequency: 482000
Symbolrate: 6875
Modulation: QAM64
Video Type: MPEG2
The bad channel (HDTV, only HD-channel I got cause the rest are locked to specific boxes)
Frequency: 418000
Symbolrate: 6875
Modulation: QAM64
Video Type: H.264
