Amppa-t Posted March 23, 2008 Posted March 23, 2008 (edited) Small annoyance when using OSD Menu. If I select Menu -> Recordings, select a recording, press Green (Info). In the Info screen RED (Record ???), Green (previous) and Yellow(next) are not working, Blue (Context) gives either help (for EPG menu ?) or Back which returns to same Info menu. There is no option to go back to recordings menu or do anything, but clear all menus and start over. Edit: Iam using default OSD Skin Edited March 23, 2008 by Amppa-t Quote
Lars_MQ Posted March 23, 2008 Posted March 23, 2008 As always OSD-Back key will work. The Color buttons have no function in this case. Quote
Amppa-t Posted March 23, 2008 Author Posted March 23, 2008 As always OSD-Back key will work. The Color buttons have no function in this case. Using Space instead of Esc in remote solved this Thanks. Quote
