MCRemote and Vista64
Curlo
Hi!
Does anyone have a working solution for vista64 and MCE remote plugin using MS MCE Remote V2 and original usb receiver. It works in Vista32, but in Vista 64 mymceremote2005 plugin won't do nothing, only working keys are normal numbers and so on, which are mapped as keyboard commands and they work without plugin. I would appreciate any help.
Hi!
Use learns function in "Options- Input" to teach the buttons of your MCE remote. Each key may need to be assigned manually to get it working.
I tried that. Nothing. In vista32 it works fine. Maybe have to use vista32.
No solution, anyone?
You can use a third party software like EventGhost, Girder or my LM Remote KeyMap utility to map the MCE Remote buttons for DVBViewer (and for other software as well).
Regards,
Stéphane.
Thanks! Now I just have to install Vista 64 and test.
