Dadag Posted March 25, 2008 Posted March 25, 2008 Hi, I am running DVBViewer Pro 3.9.2 with TT S2 3200, to few days ago the USALS function worked well using BDA 5.0.0.12 and API dll 1.0.1.4 (1.0.1.8 not detecting the CAM) but now some time the motor go to the position zero. This seem more an soft error than hard error, because after restarting DVBViewer the motor go to the good position. I have see that other API.dll more recent exists but I havent found where to download it. Maybe one collection in the download section can enable to test and update it. Quote
Dadag Posted March 25, 2008 Author Posted March 25, 2008 (edited) Here is the latest version (1.0.1.15). Thanks, Euh, the dll size is reduced to 80kB from 180kB (1.0.1.4 and 1.0.1.11), I think that many entries points are deleted ?? Edited March 25, 2008 by Dadag Quote
CiNcH Posted March 25, 2008 Posted March 25, 2008 Most likely this one has been compiled in Release mode, and the other one in Debug mode (which adds additional information so that debugging becomes possible). Quote
Dadag Posted March 25, 2008 Author Posted March 25, 2008 Well, without debug informations the size can be reduced, I will try it this night. Quote
Dadag Posted March 26, 2008 Author Posted March 26, 2008 (edited) 1.0.1.15 seem work as 1.0.1.4 and 1.0.1.11 at first view, but I still have problem with USALS function working well from 42E to 30W after updating, 19 january, to 3.9.2.0. To 2 weeks ago after one software crash, all major parameters are losts. It exists numerous parameters for the tuning, this parameters are very few documented, it is possible to found more detail how to setup. Edited March 26, 2008 by Dadag Quote
Dadag Posted March 26, 2008 Author Posted March 26, 2008 1.0.1.15 seem work as 1.0.1.4 and 1.0.1.11 at first view, but I still have problem with USALS function working well from 42E to 30W after updating, 19 january, to 3.9.2.0.To 2 weeks ago after one software crash, all major parameters are losts. It exists numerous parameters for the tuning, this parameters are very few documented, it is possible to found more detail how to setup. SOLVED : I found curious entry DiSeQc in the setup.xml file, removed this entry and now USALS is working well using only the diseqc.xml file. Quote
