Cachito Posted March 26, 2008 Posted March 26, 2008 Hello I've just bought DVBViewer and have a problem: the program works well for some time (usually around 10/20 minutes) till it get the screen black and didn't respond to mouse clicks. The same happen when its recording... My desktop is a Dell xps420. TV card is Hauppauge WinTV HVR-1200 (Model 71xxx, Hybrid DVB-T) with driver version 1.22.25200.0 (19/07/2007) Video card NVidia GeForce 8600 GTS (256MB) driver version 7.15.11.6222 (06/07/2007)- Support file attached. Thanks in advance J support.zip Quote
Lars_MQ Posted March 26, 2008 Posted March 26, 2008 try renaming the plugins folder in the DVBViewer program folder to plugins1. Quote
Cachito Posted March 28, 2008 Author Posted March 28, 2008 try renaming the plugins folder in the DVBViewer program folder to plugins1. Hi Thanks for your reply. I did it, but the problem persist. I've attached a new support file. Any idea ? Thanks in advance J support.zip Quote
Cachito Posted March 29, 2008 Author Posted March 29, 2008 Please, I still need help on this topic. Thanks in advance J Quote
Cachito Posted April 3, 2008 Author Posted April 3, 2008 (edited) I've downloaded DVBViewer Pro record service plugin and all records worked very well. Then, I decide to check Windork Vista Event viewer and I saw errors related with NVidia video driver, so I can conclude that Nvidia drivers are working not so good on Vista box and they are disturbing DVBViewer... I'll try to update drivers or something else but if somebody found a possible solution please don't hesitate to post it here. Thanks in advance J Edited April 3, 2008 by Cachito Quote
