ardua97 Posted March 27, 2008 Posted March 27, 2008 is possible to auto execute DVBViewer when i turn on the computer Quote
tjabbaranx Posted March 27, 2008 Posted March 27, 2008 is possible to auto execute DVBViewer when i turn on the computer I have created a shortcut on "DVBViewer.exe" and i put it in Autostart folder. Works fine with me after i deleted the "ballontips". Quote
ardua97 Posted March 28, 2008 Author Posted March 28, 2008 I have created a shortcut on "DVBViewer.exe" and i put it in Autostart folder. Works fine with me after i deleted the "ballontips". thank you very much yesterday i scheduled DVBViewer on start in the vista scheduler and it work ok what is the "ballontips" ? Quote
glxblt Posted April 2, 2008 Posted April 2, 2008 Just as a warning, I had problems in Windows XP using the Task Scheduler. DVBViewer.exe got executed "too early" and that caused a variety of problems ranging from minor control problems to full inability to achieve any kind of picture. I used the alternate method, creating a shortcut to the "startup" -folder in the start -menu, and it worked fine. Quote
