Infinity USB Unlimited
Kilyan
Hello!
I tried to search on the them of this topic, but found not relevant solution. My question is that does an installed Infinity USB Unlimited device work as a Phoenix reader under the latest purchased DVBViewer?
1. If yes, please could you tell meg how?
2. If yes, does it update the card as well?
Thank you very much.
To watch Pay TV with the DVBViewer you need a common interface (CI), common access module (CAM) and you subscription smart-card.
No other solutions are aloud.
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "common interface" (CI) and the corresponding "common access module" (CAM) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
