Webserver Plugin for chinese?
kenmawk
Dear Sirs
Will you upgrade the Webserver Control to support Chinese(Traditional) EPG?
Do you have iMON remote plugin?
Thank You
Ken
I will update the webserver as soon, as I have a clue, how to get it to show chinese. ATM I don't know if it is even possible, with the data available from the DVBViewer. But I take a look into it.
No but you can setup the imon manager to send keystrokes to the viewer and set up the input options of the viewer accordingly, so it will work.
Try the following:
first close the webserver plugin. Make a backup of the web folder with the html files.
Open the html files in the web folder with a fitting editor (notepad will do) and change the line
<meta http-equiv="content-type" content="text/html;charset=ISO-8859-1">
to
<meta http-equiv="content-type" content="text/html;charset=Big5">
Does it change anything?
  • 2 months later...
Try the following:
to
this change fix the menu text only, but the EPG content still can't display.
one character is 2 byte, but it change it byte by byte like this "¨D¨ä¤@­Ó¹Ú"
