blizzarduk Posted March 31, 2008 Posted March 31, 2008 (edited) I have had a very annoying problem that when recording TV DVBViewer will crash at any time, usually around an hour in. I have 70gb space left so I know it is not due to that. Sometimes I am lucky and it will last the length, but other times it wont, and it can be really annoying. Sadly I can only remember some of the error message, it was a DLL file, and I remember checking it out and it was an essensial windows file. I am sure it looked like NTDL or something like that, it was not a codec file as far as I can tell. I will make sure I note it down next time it happens. So far I have only recorded using HDTV, so I am unsure if that is relevant. I am using FireDTV but I am sure the same happened with my SkyStar 2HD which I also use. Any ideas ? I understand the exact filename will be very important, I will add it to this thread if I can't be helped by the above info. I use Windows XP, Core 2 Quad 6600, 2gb ram, 500gb HDD, Sky TV. Edited March 31, 2008 by blizzarduk Quote
Lars_MQ Posted March 31, 2008 Posted March 31, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
