invincible Posted March 31, 2008 Posted March 31, 2008 Hi all, i purchased recently a copy of DVBViewer pro and i have one question about DVBViewer server. I have one pc and a laptop and i using the server on the pc and a copy of the DVBViewer on the laptop. The problem is the laptop copy of DVBViewer stop run and ask me for login and password when the program on the pc is run perfect. So my question is ...¿do i must purchase another copy of DVBViewer to use streaming on lan? ¿why on the first instalation on my pc runs ok and on the laptop ask me for login and password with a must restart of the program, every hour more or less?. Quote
SimonP Posted March 31, 2008 Posted March 31, 2008 (edited) When you installed it on your laptop it should have asked for your email address and password. For some reason it sounds as if it didn't so you could either uninstall and reinstall it or, if you're brave enough, use RegEdit to go to [HKEY_LOCAL_MACHINE\SOFTWARE\CM&V\DVBViewer] on your PC where you'll find the login details. Export that entry then import it on your laptop and it should fix the problem. Edited March 31, 2008 by SimonP Quote
invincible Posted April 1, 2008 Author Posted April 1, 2008 When you installed it on your laptop it should have asked for your email address and password. For some reason it sounds as if it didn't so you could either uninstall and reinstall it or, if you're brave enough, use RegEdit to go to [HKEY_LOCAL_MACHINE\SOFTWARE\CM&V\DVBViewer] on your PC where you'll find the login details. Export that entry then import it on your laptop and it should fix the problem. Well im tried that, uninstall, install again and now video render graph is wrong...conections from DVBViewer to dd7734.kasserver.com and now no stream rendering to the client.... Admins? i need support Quote
