Disable AV?
Lydecker
Please can someone tell me what the 'disable AV' option does under the recorder options.
Many thanks
It does what it says. When you minimise DVBViewer while recording, it disables the audio and video so it won't disturb you if you're not watching it.
Both AV are not available, even the DVBViewer is not minimized, when "Disable AV" is checked. :)
