Disable AV not working
potnoodles
I have 'default disable AV' ticked.
When I record and minimise either with the minimise button or with the on screen menu AV is not disabled - at least the audio is still playing so I assume the video is being decoced as well.
Any Ideas?
Vista Home premium
Nvidia Geforce 7650GS
Creatix SAA7131 triple capture device
Edited by potnoodles
tick disable AV on minimize in the options. DisableAV for timers only keeps AV disabled if disabled. otherwise it has no effect.
OK thanks, eventually found it under TV + Radio (it is abit confusing )
