i cannot scan ...
badtrip
Hi everybody.
I have a huge problem!
I have 4 dishes, i have no problem with 2 of them (Turksat and Hispasat) but the other2, i cannot scan them all!
Both Hotbird and W3a only scan 3 frequencies!
I thought the problem was because of the beta driver 4.4.1, so i formatted my pc and set up 4.32 driver..
I stille have the same problem right now.
But in altdvb i can scan whole trasnponders..
I dont thik its an hardware issue but, couldnt find what is the REAL thing..
Please help me...
Support.zip attached!
Thank you..
Edited by badtrip
If it works with altdvb, it should work with the DVBViewer as well. Check with transedit which diseqc setting correspond to the 4 different satellites (A/A, B/A, A/B, B/:blush:
This is what i know..
LNB1 Turksat A-A
LNB2 Hotbird B-B
LNB3 Hispasat A-B
LNB4 W3a B-A
Now i can scan LNB1 with no problem, but the others do not find any frequencies :blush:
What can that be?
Aslo tried DVBViewer it works fine :(
NOTE: By the way i installed a slipstreamd Xp installation,
is SP3 causing problems? iCouldnt install TS440 and its software, an error said that i HAD to upgrade to SP2..
didnt understand it at all!
Edited by badtrip
By the way..
I downloaded the transponder ini file from kingofsat..
i deleted the feed transponders..
and the tv channels left in the list.
May this be the origin of the problem?
Unfortunatly i wrote those ini files over the original ones, so..
Could some pls send me an up-to-date ini file to try?
I'm formatting again :blush:
Edited by badtrip
Sorry my 3rd post should be like this
Aslo tried dvbdream it works fine :blush:
Edited by badtrip
pls. attach the corresponding inis that you've imported from kingofsat. Then I can have look what's wrong with your diseqc settings.
Hi Derrick..
Thank you for replying my calls.
I uploaded my transedit EXPORT files, and the ini files from kingsofsat.
as you see i can only scan , hotbird 11278, W3A 11283..
I have two sattelites combination (hotbird-W3) at one DISH, the others are individual..
But still, i can scan other frequencies via other dvb players..
By the way, can you please tell me, what is the diffrence between the TP files in CMUV and the TP files in root directory?
when i use transedit, the ones in the root TP's folder convert themself to a recognised format for DVBViewer.
So what is the other one used for?
Thank you very much..
ini_s_and_the_exported_channel_lists.rar
The location of the files depends on the user mode. Just click on help and you'll see.. ..same for trasnedit.
You have to activate diseqc before scanning either in transedit or in the DVBViewer. Your inis are without (diseqc -> none).
Well first of all i'm deleting the old ones,
then pasting the new ones from kingofsat..
in transedit i'm setting the diseqc to B/B for Hotbird.. (shown in the ss.)
but still no other frequencies!
it scans only 1 frequency (11278), it asks me whether i wanna save or no! I saved it and the ini file changes to a recognised format.
then i export the file to a INI file from transedit and import it in DVBViewer
So I have them already SET-UP !
And try again scanning, then...oops! It doesnt even find 11278!
Could you please fix the inis ?
So that i can find what is wrong?
Because right now i didnt really understand what it is !
Please send me the fixed ones, and i'll also try this your way!
Thank you Derrick ...
Those last 4 inis do show diseqc settings. Dunno whether the settings are correct but you can find out, if you use them.. ;)
Well the settings shpoould be right as said before my diseqc settings are
LNB1 Turksat A-A
LNB2 Hotbird B-B
LNB3 Hispasat A-B
LNB4 W3a B-A
and w3a and hotbird can scan only one channel!
if the settings were wrong, it shouldnt have scanned any transponders..
Is there anything i can do about it?
I'm kind'a pessimistic right now:(
And the other thing is service pack 3 support..
Does servicepack3 has situations with SS2 card drivers and software that is needed for DVBViewer installations?
As i said before TS441 gives me an error while installing the software (not driver) an shows a message that tells me that i have SP3 installed and i need to UPGRADE ( ! ) to SP2!
Anyone had that problem before?
or is that a common thing??
Really thanx Derrick..
You helped me a lot..
..maybe, you should start again from scratch. Your installation seems to be a mess ;)
Well my computer has a FRESH windows installation.
I did install it this morning!
Its not a mess, there i something but i couldn'd find it out..
Would you take a SS from Hotbird.ini under CMUV > Transponders?
No need for SS..
Please look for my 7th and 10th posts, i've already post'em..
LNB1 Turksat A-A
LNB2 Hotbird B-B
LNB3 Hispasat A-B
LNB4 W3a B-A
I suppose you confused diseq settings; it must have been like this:
LNB 1 Turksat A-A
LNB 2 Horbird B-A
LNB 3 Hispasat A-B
LNB 4 W3a B-B
What i suggest to you is:
Just erase all the inis both under CMUV > Transponders and DVBV > Transponders Folders; additionally channels.dat channels.bak, favourites.XML(under CMUV)
Download current raw inis from Kingofsat into CMUV > Transponders Folder
Open DVBV and prepare a temporary channels.dat; i mean from any transponder scan one known TP and save this list (It is needed for Transedit to recognize DVBV.)
Open Transedit and adjust diseq settings as i gave above.
Scan with Transedit and after scanning complated export this scanned ini as "Hotbird.ini"- for instance
Open DVBV and open Channel editor and import these inis and save.
Edited by ricabullah
Unbelievable!
İ've been using Hotbird as BB for 2-3 years but now when tried BA it did work!
Maybe some diseqc problem i don't know but thanks anyway both of you Derrick and Ricabullah..
Now it scans fine, still no image (have to format the sp3) being lazy nowadays..
Edited by badtrip
Unbelievable!
"still no image" ???
