Tevion DVBT
Kowalski
Hi have a Tevion DVBT card installed on my PC and do nto have the original interface software that comes with the card, will DVBViewer allow me to make use of this card?
Im a bit of a newbie to all this :blush: so any help is appreciated and I will try to respond to any questions you pose as best I can
Hello,
please download the tool TransEdit MMC -> http://www.DVBViewer.com/download/Transedit_MMC_Demo.zip
with this you can check the support for DVBViewer.
you must ensure that the device is listed under Settings -> Hardware, is it true you can make a scan
for the scan you must select in the left list the "Terrestrial EUR", then you can drop "Scan All"
if you know the current frequencies you can double-click in the right list
if you find channels, so DVBViewer will work.
:blush:
