EPG Font Size
manlyman
How do you change the EPG font size, you know the TV-Guide etc. screen? The standard size is way too small for TV screen use. Tried to search for this on the forum the search says EPG is too short a word to search for. I know there was a skineditor once but I really think this should be an option in the program itself. I took a look at the members filesection but couldn't figure out what to try - too much choices.
So what do I do, is there a textfile I should edit or what? Thanks in advance.
As far as i know is this not possible.
For TV scren you better use the OSD (OSD Menu [Esc])
Use the Search box and click Google
Oh thanks, I thought there has to be an OSD function for this as well! Well a newbie has a newbies questions...
I'm using a gamepad to control DVBViewer so I'll have to reconfigure that key.
I can tell you it's a fun experience being able to control your TV with a Xbox 360 wireless gamepad!
