Execute command after recording finished
Kuni
I've looked everywhere but I can't seem to find it/how DVBViewer could execute a command when a recording is finished.
Ideally it would be another option in the drop down menu Record/Time/AFTER RECORDING/<run command>
There's probably something I've missed, can anyone help me?
If Scripts are enabled (Options > Scripts) the ...\DVBViewer\Scripts\stoprec.vbs will run at the end of each recording.
If you just like to run a Programm for examle notpad add
OSD.ExecNewProcess "c:\Windows\notepad.exe","", False, False
The documentation to the file is in "DVBViewer COM Interface" (Mitgliederbereich > Sources)
Excellent, thanks for the info!
