Niklas Posted April 8, 2008 Posted April 8, 2008 (edited) Hi Just got dvbserver to work , but cant get encrypted channels to work when using server. It works fine in Dvdviewer. Any ide ? Br. Niklas Update: Working now Edited April 8, 2008 by Niklas
RR7 Posted April 16, 2008 Posted April 16, 2008 Hi Just got dvbserver to work , but cant get encrypted channels to work when using server. It works fine in Dvdviewer. Any ide ? Br. Niklas Update: Working now how did you make this work? when i choose an encrypted channel, i just get 'hardware not found'. which plugin(s) are you using?
RR7 Posted April 16, 2008 Posted April 16, 2008 (edited) how did you make this work? when i choose an encrypted channel, i just get 'hardware not found'. which plugin(s) are you using? never mind, i worked it out. for anyone else wondering, you MUST set your unicast device to have the 'Has CI Module' checkbox enabled, otherwise DVBViewer just throws the no hardware error. i can confirm that running DVBServer, and DVBViewer on a seperate computer, i can receive encrypted channels [removed] this program does everything! Edited April 17, 2008 by Tjod
Tjod Posted April 17, 2008 Posted April 17, 2008 Two days ban. You should read the Forum Rules. http://www.DVBViewer.info/forum/index.php?act=boardrules § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "common interface" (CI) and the corresponding "common access module" (CAM) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
