franki Posted April 10, 2008 Posted April 10, 2008 Hello.. I am using DVBViewer 3.9.1.0 with Windows Vista U. 32bit.. I can see subtitle when using VMR7 video Mixing Renderer. But When I use Vista Enhanced Video Renderer, the subtitle will be disppeared... Can you help me to fix this problem? Thx a lot.... Quote
Tjod Posted April 10, 2008 Posted April 10, 2008 Tay if it helps to Install the current version 3.9.2.0. Quote
franki Posted April 10, 2008 Author Posted April 10, 2008 Thx for your reply... My friend bought 3.9.2.0.. and give me try... I also get the same problem. Does the problem come from teletext(801)? Because australia is using telext for supplying subtitle? Quote
