DeDynamic filter
Lele81
In the latest version there isn't the blue X of dedynamic in the systray, i have already checked the box to use dedynamic filter in the options. Where can i download it?
Nowhere. :( The "dedynamic.ax" (in the filters directory) belongs to the installation pack of the DVBViewer. Did you check its use with GraphEdit?
Bye, Oliver
I have solved coping the DCDSPFilter.ax in the filters directory that there isn't present in the latest package of DVBViewer.
Right, I've just tested it and sent a mail to Christian.
Bye, Oliver
PS: Christian told me he deliberately removed the filter from the package because of severe problems in several cases. He is still thinking about a solution. Maybe the installation routine will feature an option to install the DCDSPFilter.ax or not.
Edited by Oliver
