gehru Posted April 14, 2008 Posted April 14, 2008 I come from Taiwan, now uses the version is 3.9.3.35 beta. I likes DVBViewer very many nimble elastic function but being a pity very much, is unable normally to display traditional Chinese EPG. this version in Hong Kong actually is may normally display traditional Chinese EPG . can be because Hong Kong uses DMB-TH+H.264+AC3, but Taiwan uses DVB-T+H.264+HE-AAC? Whether may support Taiwan in next BETA to be allowed normally to display traditional Chinese EPG. Quote
Lars_MQ Posted April 15, 2008 Posted April 15, 2008 Whether may support Taiwan in next BETA to be allowed normally todisplay traditional Chinese EPG. First take a look at this: http://www.DVBViewer.info/forum/index.php?showtopic=25717 Quote
gehru Posted April 15, 2008 Author Posted April 15, 2008 (edited) First take a look at this:http://www.DVBViewer.info/forum/index.php?showtopic=25717 Thanks This is very brilliant introduced. I also looked at a same content Chinese edition. http://forum.hkepc.com/viewthread.php?tid=...;extra=page%3D2 But said on like the Hong Kong authors, uses above 3.9.3.15 Beta the edition to have support traditional Chinese EPG. But I in Taiwan, I use 3.9.3.35 Beta actually not to be able to display traditional Chinese EPG, I determined time zone has supposes GMT+8. I to want possibly to be DVBViewer has not supported Taiwan (DVB-T+H.264+HE-AAC) to use traditional Chinese EPG. Edited April 15, 2008 by gehru Quote
hackbart Posted April 15, 2008 Posted April 15, 2008 Depends on, if you could create a transponder dump from one of your channels we might be able to get it working in a similar way we did for the chinese traditional context. Christian Quote
gehru Posted April 15, 2008 Author Posted April 15, 2008 (edited) Depends on, if you could create a transponder dump from one of your channels we might be able to get it working in a similar way we did for the chinese traditional context. Christian Thanks, I have taken down two section of ts file, refers for you. I hoped this is you needs, if is not, please again tells me. 04-16_00-16-32_HiHD_.ts HD 21.MB 04-15_23-53-21_PTS_.ts SD 23.3MB Edited April 15, 2008 by gehru Quote
gehru Posted April 15, 2008 Author Posted April 15, 2008 Depends on, if you could create a transponder dump from one of your channels we might be able to get it working in a similar way we did for the chinese traditional context. Christian Moreover also provides epg.dat and the channels.dat two files. channels.dat epg.dat Quote
hackbart Posted April 15, 2008 Posted April 15, 2008 Okay, could you download transedit from the members section and press analyze on a valid frequency. After the analyzer window is visible, open the popup menu on the pid list, press the "select all" entry and finally the record button. Christian Quote
gehru Posted April 15, 2008 Author Posted April 15, 2008 Okay, could you download transedit from the members section and press analyze on a valid frequency. After the analyzer window is visible, open the popup menu on the pid list, press the "select all" entry and finally the record button. Christian Thanked, I already deferred to the step to record TS files. The frequency is 533,000 Terrestrial (TWN) 533000 04-16 06-39-45.ts Quote
hackbart Posted April 16, 2008 Posted April 16, 2008 Is the attached text correct? I still got confused if i deal with code page 950 (traditional) and 936 (simplified). Christian PS: What is the exact difference between both writings? They exactly look equal in my western eyes Quote
gehru Posted April 16, 2008 Author Posted April 16, 2008 Is the attached text correct? I still got confused if i deal with code page 950 (traditional) and 936 (simplified). Christian PS: What is the exact difference between both writings? They exactly look equal in my western eyes good, that attaches the files the frequency channel name is right. Simplified and traditional difference: 1. simplified forms are China use, the traditional form is Taiwan uses 2. characters codes and the font is all dissimilar Quote
zhenmin Posted April 17, 2008 Posted April 17, 2008 Is the attached text correct? I still got confused if i deal with code page 950 (traditional) and 936 (simplified). Christian PS: What is the exact difference between both writings? They exactly look equal in my western eyes Wikipedia Traditional_Chinese Simplified_Chinese Quote
gehru Posted April 19, 2008 Author Posted April 19, 2008 Thank you very much, DVBViewer Pro 3.9.3.40 Beta already was allowed to support Taiwan DVB-T Chinese EPG. 1.The frequency channel name code is not right, but may use the frequency channel editor voluntarily to change. 2.The program material finally two lines of codes is not right. Quote
