How to get a recording event?
disaster
Hallo!
I would like to get event messages with my plugin - i'm not shure if the function eventmsg is the right one - isn't it? Or how do i get with a .dll (without COM) such events?
Stefan
You can't. This kind of stuff only works for COM.
Mhm but i cannot use COM for two instances :-(
OK perhaps i should write what i would like to do. I would like to have two running instances of DVBV each connected to a single DVB-C Card. And i would like to schedule recordings in DVBV 1 and then transfer them to DVBV 2.
So my idea was on each Recording ADD / DELETE in DVBV 1 todo the same events in DVBV 2.
