Bjur Posted April 16, 2008 Posted April 16, 2008 (edited) Hi 1. When will there be a new version available with working DVB subtitles, cause it doesn't work in the latest version, but have seen it works with the newest BETA, so I'm hoping there will be a stable version in the near future? BTW. I'm from Denmark, and know others have had these problems. 2. I'm having problems when watching soccer in HD, it doesn't run smooth. I have tried both 50/60 hz but no difference. And I'm using PowerDVD as HD renderer. 3. Is it possible to make font bigger in EPG menu or EPG plus, because it difficult to read it. Any suggestions? Edited April 16, 2008 by Bjur Quote
maier2505 Posted April 18, 2008 Posted April 18, 2008 Hi1. When will there be a new version available with working DVB subtitles, cause it doesn't work in the latest version, but have seen it works with the newest BETA, so I'm hoping there will be a stable version in the near future? BTW. I'm from Denmark, and know others have had these problems. 2. I'm having problems when watching soccer in HD, it doesn't run smooth. I have tried both 50/60 hz but no difference. And I'm using PowerDVD as HD renderer. 3. Is it possible to make font bigger in EPG menu or EPG plus, because it difficult to read it. Any suggestions? Xp or Vista? Which Hardware ? to point 2.: Do you have sometimes short jumps in the video, or is it more a shattering for a few seconds ? I had this shattering, too. I now did two things: 1. Disable everything in Vista, which leaded to background tasks 2. Changed from ATI 2600pro to Nvidia9600GT Now it seems, that I had a victory over the shattering... Best regards maier2505 Quote
Bjur Posted April 19, 2008 Author Posted April 19, 2008 Xp or Vista?Which Hardware ? to point 2.: Do you have sometimes short jumps in the video, or is it more a shattering for a few seconds ? I had this shattering, too. I now did two things: 1. Disable everything in Vista, which leaded to background tasks 2. Changed from ATI 2600pro to Nvidia9600GT Now it seems, that I had a victory over the shattering... Best regards maier2505 XP. HW: Intel Core 2 duo E6600, 4 GB memory, graphic card: Gigabyte NVIDIA Geforce 7600. And regarding the HD. It's not jumps but flickering when fast moves. I have downgraded to version 3.9.0.0, but still have problems with DVB subtitles, and have heard that the beta version got it working, so I' really interested in when a new version is available? Quote
Lars_MQ Posted April 19, 2008 Posted April 19, 2008 so I' really interested in when a new version is available? When it's ready. Quote
