Irish FTA Terrestrial
Spud
I installed a Peak DVB-T PCI card yesterday. It shows up in device manager as a "Philips SAA713X, Hybrid Capture Device". It works ok with DVBViewer V 3.9.2.0 and I can tune in the local FTA HiDef test station, some radio stations and encrypted TV stations also tune in ok.
My problem is that I can't tune in the four main FTA TV stations, these all reside at 738 MHz (CH 54) along with the national radio stations. I did a bit of research and downloaded TransEdit but I still can't find the missing stations with blind scan or just scanning the 738 MHz frequency. I might be doing something wrong of course, any sugestions would be appreciated.
I can read the following info from my STB for the main program RTE 1
Modulation: QAM 16
Guard Interval: 1/32
Transmit Mode: 8K
Video PID: 1101
Audio PID: 1201
Hierarchy Mode: 0
HP Code Rate: 3/4
LP Code Rate: 1/2
Jim.
Have you already tried to shift the frequency a bit, let's say to 737.9, 737.8... 738.1, 738.2...?
Thanks Grriga,
I trried that just now and it worked at both 737.9 and 737.8, I have all the stations now.
Jim.
According to Wikipedia the correct frequency is 737.833 MHz.
