PROJECTX demux problem
subdvb
Hi all,
can anyone help.
I am unable to get Projectx to work with .ts files created by DVBViewer 3.9.2.0.
When loading files into Projectx I get no frames just the following error message in the preview window
"error while decoding frame not enough data in buffer. data seems to be MPEG-4/H.264"
Am I missing something obvious?
Projectx 0.90.04.00.b23/23.02.2008 OoZooN.TV Edition
DVBViewer 3.9.2.0
firedtv s2 sat card
cyberlink 7.x codec
Note 1: PVAStrumento also gives me the following error message
VIDEO #1
ALERT> No sequence header found for info.
AC3 AUDIO #1
Format: 2/0
Sampled at 48.0 kHz.
First PTS: 13:57:33.176
ALERT> Cannot sync. Not enough data.
Last fileset:
0 total bytes written
Sync estimate at EOF:
AC3 Audio #1 : sync
Note2: mpg recordings work fine.
Note3: ultimately I want to add subtitles to a HD .ts recording- is this the right way to proceed?
In anticipation thank you all for your help
These tools can't cope with H.264. Have a look in HDTV and Conversio&Encoding. There you'll find many threads concerning H.264 processing..
