Channel editor group feature choice needed
Dadag
The channel editor presents channels only grouped by category, because some provider are changing often transponder content, rescanning keep all dead channels, it is more simple to clear the transponder content then rescanning it. Deleting transponder content is many more easy when it is possible to group channels by transponder.
One simple test : try to delete transponder content using channellist grouped by transponder-> select channel -> open channel editor -> delete channel -> close editor then select another channel and restart cycle. With 10 to 20 channels this become very annoyant.
do a scan with update channelnames and then delete all non bold channels in the editor.
Or use transdit. It's not the fault of the viewer your providers are not organized enough ;)
This isnt so easy because the channel still sorted by category and channels in one transponder can be in many categories.
