riviera Posted April 19, 2008 Posted April 19, 2008 Hi! I've a problem with DVBViewer 3.9.26 (beta), SkyStar2 (Technisat drivers 4.4.1) and some Hispasat 30ºW channels. If I chek "Open whole transponder" option, I can watch Retevision DTT spanish channels which are transmitted by Hispasat (11655 H 12960, 12622 V 12960, etc), but I can´t watch the channels of transponder 12456 v 30000 5/6, I tune in with 50% level signal but are frozen and see many pixels. Instead if I uncheck "Open whole transponder" I can wach the 12456 transponder channel´s but Retevision's don´t. Can I do something to solve this problem? Thanks. Quote
Derrick Posted April 19, 2008 Posted April 19, 2008 The only solution with DVBViewer is to switch between the modes manually. For Retevision the entire mux is necessary. The high rate mux with sr=30000 is too much for the SS2. There you need hardware filters. With the SS2 you could try altdvb. There you'll find an option to switch the mode automatically.. Quote
riviera Posted April 20, 2008 Author Posted April 20, 2008 The only solution with DVBViewer is to switch between the modes manually. For Retevision the entire mux is necessary. The high rate mux with sr=30000 is too much for the SS2. There you need hardware filters. With the SS2 you could try altdvb. There you'll find an option to switch the mode automatically.. Ok, thanks. I understand that it's a SS2 problem. With another dvb-s card would have solution? Thanks Quote
Derrick Posted April 20, 2008 Posted April 20, 2008 ..no problem with other cards if they are not connected via usb1. Quote
