PLEASE HELP! iredeto CI interface crashes
Hi everyone, I have major issue with my CI module since installing the latest version of DVBViewer. It was working perfect for over 9 months beforehand but now it will either say E16 Service currently scrambled and do nothing, or it will say E00 Service currently not scrambled but no chanels available. At times it will say E34 Service currently descrambled and then it will work for about 20 minutes and then it will crash with E16. All non encripted channels work fine. CI appears to be working correct as if the card is removed it will say Insert Smart card, then Checking smart card and then Either E00,E34 or E16 (mostly E16). Card works perfect in the provider (Select TV) set top box and in my friends set top box which is different brand. Also since the last installation of DVBViewer the EPG (incl terestrial) is all wrong altough the time zones and time and all related settings are correct. Could someone help me with this issue please, I have been trying everything I can think of but with no succes. Even got my service provider to update my Smart Card.
PLEASE HELP
Kind regards Steve :bye:
Vista x64 Home Premium, Intel Core2Duo @1.86, 580GB HD, Pioneer Drive, Antec case, Fire DTV S2 CI, Aver Media DVB T HD hybrid PCI FM, Twinhan DVB S CI, Nvidia 8500 GT, Cyberlink Pure Video, Logitech DiNovo Mini remote.
  • 1 year later...
Hi Steve
Did you find the answer to this? I'm having a very similar issue with DVBViewer needing about 5 minutes sometimes to bring up channels. I otherwise get the Ë34 - Channel scrambled message. Everything seems to work fine in DVB-TV app. I too run x64 Vista. What version of DVBViewer were you running before... is that worth installing?
