howi42 Posted April 22, 2008 Posted April 22, 2008 I tried to load a different .remote file, but I cannot get it to work. Copied a new .remote file into the /remotes directory, but the new file does not appear in the loading dialog. Anything I forgot ? Thanks, Wolfgang Quote
Lars_MQ Posted April 22, 2008 Posted April 22, 2008 You use the remote folder in the configdata folder? (in DVBViewer menu help -> config folder) Quote
howi42 Posted April 22, 2008 Author Posted April 22, 2008 You use the remote folder in the configdata folder? (in DVBViewer menu help -> config folder) Danke, das wars schon. - Wolfgang Quote
