Tjod Posted April 22, 2008 Posted April 22, 2008 The Default settings from the DVBViewer are selected in a way to work in all situations. In most cases you can tweak the settings for a faster zapping. But if you have trouble first check if it works with the Default settings. Here the settings which may increase the zapping speed: Options > DirectX Video Renderer = Overlay Audio/Video Format Detection disabled. Options > TV + Radio Fast Channel Switching enable Channel Switching Delay disable Options > Hardware Stop Stream while tuning disable New tuning method enable View > Filters > DVB Source Max. Queued Audio (TV/Radio): 250 ms Max. Queued Audio (File): 0 ms Latency: 20 ms (if I use lower values i get trouble with some channels) http://www.DVBViewer.info/forum/index.php?...ost&p=90024 Change DiSEqC = None in the Channel Editor if you did not need it. Sorting the channels in such way that channels on the seam frequency are in a row. And remember some settings do not work with all channels/decoder/hardware. If you get trouble go back to the default settings. Quote
